Thread: Actuator's
    Jan 2012
    Mission, TX
    16
    Actuator's
    In my pool, the valves are automated using the easy touch control panel and wireless remote. I had 3 pentair compool actuator valves that went bad and would no longer work. They were replaced with the brand super pro. Should I be concerned or are they just as good as the pentair. Please advise. My home warranty covers my pool equipment and all I pay for the service is a deductable fee of $100.
    12,000 Gallon IG Saltwater, Blue Quartz/Glass Bead Plaster, Pentair Quad 80 Cart Filter, A&A Infloor Cleaning System, Pentair IC60 SWG, EASY Touch Control Panel with 4Button Wireless Remote, Pentair Inteliflo VS, Pentair Ultra-Temp 120 Heat Pump, FLOWVIS Check Valve & Flow Meter 2"
    38,235
    Re: Actuator's
    With 3 failed Pentair actuators, what makes you think they are better
    Very odd that happened. Normal for a home warranty to buy as cheap as possible though.
    Jan 2012
    Mission, TX
    16
    Re: Actuator's
    The home warranty sent a technician out for service. I had a hunch that they replaced as cheap as possible. I just wasn't sure. I was going to try to have them replaced with an actuator that is comparable in quality as the pentair but I wasn't sure if it was worth the trouble. Please advise
    38,235
    Re: Actuator's
    No way you will get the warranty to change to Pentair. Not worth the hassle or money to change them yourself. They are really pretty basic devices that should not fail. Although I recall the Pentair did have a bad batch mentioned in other threads I think ... They may have replaced them for free depending on age.
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    Re: Actuator's
    Pentair did have a bad run of these not that long ago. If I'm not mistaken, Super Pro is an Intermatic brand. I wouldn't worry about them as I'm sure they are fine.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
