Thread: Hayward Sand filter sight glass leaking
    Jul 2015
    Edison/NJ
    19
    Dear Forum-mates:
    New pool owner here again.
    I have a Hayward sand filter (side mount - S244s) My sight glass leaks when I am doing backwash/rinse.
    From another thread I realize that there is a difference between leaking during regular filter operations vs. backwash operation.
    So if it leaks during backwash/rinsing, can I do anything to fix it?
    - I tried looking at the parts diagram couldn't tell if there is an O-rignt.
    - I tried using some Teflon tape. It didn't help much.
    - The spider casket was replaced by a pool company last season (although now I question how good they are).
    - I also read about a "spring" that I should replace but don't know which one.
    Any specific instructions/advice on this problem will be greatly appreciated. Here is the link to the manual
    https://www.hayward-pool.com/pdf/man...210S-S244S.pdf
    Thank you!
    In-ground, liner, 25K gallon irregular, Hayward Pro Series High Rate Sand Filter S244S, Hayward filter (1 HP), Chlorinator connected. 2 skimmers, 3 returns, 1 floor drain.
    Re: Hayward Sand filter sight glass leaking
    Mine didnt have an o ring but a rubber washer like you have in a garden hose. If you buy a replacement glass it ususlly comes with the rubber washer. Local pool store should carry it.
    Jul 2015
    Edison/NJ
    19
    Quote Originally Posted by mmirav View Post
    Sent from my SM-G900V using Tapatalk
    I got a washer from home depot and it worked! Thanks for the tip.
