Results 1 to 7 of 7
Thread: Which chemical treatment do I do first, second, etc.?
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Today's readings:
    FC - .5
    TC - 0
    pH - 7.8
    TA - 240
    TH - 400
    CYA - 30
    Salt - 3500
    according to the pool math calculator, I need to add 50 ounces of bleach (Clorox concentrated @ 8%), 12 ounces of muratic acid, & 45 ounces of CYA.
    Also, do I leave the sand filter running for each addition? My pool gets 9 hours of direct sunlight & im thinking the SWG can't keep up with the loss. With that amount of sunlight, do I need to do the overnight test...? Water is clear, 91 degrees F.
    Intex Rectangular AG Ultra Frame Pool Set, 24' x 12' x 52" (8403 gal, well water)
    Intex Krystal Clear Saltwater System model number: 28663EG/54601EG
    Intex sand filter pump, 120V 1,600gph with GFCI
    Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Which chemical treatment do I do first, second, etc.?
    CYA goes in a sock in the skimmer first, more here, Pool School - Recommended Pool Chemicals.
    Add bleach second in front of a return with pump running, wait 15 minutes and add acid in front of the return.
    Make sure to keep chlorine at target at all times for your CYA to keep the pool sanitized and algae free, Chlorine CYA Chart
    OCLT is up to you. How long was the FC so low? It doesn't hurt to do one. Be sure to raise FC to 10 or more.
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Quote Originally Posted by pooldv View Post
    thanks! My FC has hovered around .5 to 1 since the install two weeks ago. have shocked it twice and added muratic acid twice. Added CYA once.
    DFW, TX
    24,450
    Yes, definitely raise FC above 10 and Pool School - Perform the Overnight FC Loss Test (OCLT) to see if anything is consuming chlorine.
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Oh my goodness...I have thoroughly confused myself with FC, CC & TC readings. (This happened because I was using the HTC 6-way test kit as well as the Aquachek Chlorine Pro test strips, Intex test strips, & Insta-test strips in an attempt to compare readings to check for accuracy.) Was not paying close attention to which test result I recorded in my log. My Bad! Here are the chemicals tested for each of these...
    HTC 6-way Test Kit Aquachek Test Strips Insta-Test Strips Intex Test Strips
    TC TC FC FC
    Bromine FC Bromine pH
    pH pH pH TA
    TA TA TA Copper
    TH CYA TH
    CYA Salt
    I've ordered the FAS-DPD test kit & should receive it August 4th. When I run out of the tests from the HTC kit, I will definitely purchase the TF-100 kit. Now, had I found this forum before I purchased all of these testing kits/strips, I would have known better what I was testing for, lol.
    Mar 2007
    San Rafael, CA USA
    12,082
    Note that the test strips testing for hardness are testing for TOTAL Hardness that includes both magnesium and calcium. What you want and that the TF-100 has is a test for CALCIUM Hardness since scaling comes from calcium carbonate, not magnesium carbonate. Since you are using well water that might be hard water, it would be good to know the CH level. Also, test strips are generally not very accurate, especially for some of the tests such as CYA.
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    That makes sense. The pool store tests for calcium hardness level. So much to learn!
