Thread: dirt from jets when set on filter and even on waste
    Jul 2015
    Chilliwack
    1
    Hi everyone,
    I am hoping this forum could help me out with my pool. This year seems to be the year trouble spots starting to show up.
    What could be the culprit if ​I am vacuuming with setting on filter and even on waste and dirt coming through the jets onto the pool water.
    diyana.....inground kidney shaped pool/sand filter/hayward pump and filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Re: dirt from jets when set on filter and even on waste
    Welcome to TFP!
    Sounds like you are on the verge of an algae bloom due to low chlorine levels or high CYA levels or both. How about some test results and recent history of your chlorine and CYA. Here is what we are looking for, Pool School - Getting Started
    I don't know where chilliwack is but it is a cool name! Please update your location in your settings so we know what climate you are in, climate is important info for us when helping you with your pool.
    Jun 2015
    Raleigh
    357
    There should be no water coming from return jets when vacuuming to waste.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
