Thread: Odd Occurence
    Jun 2015
    Bedford hills ny
    46
    Odd Occurence
    For the last month my water had been pretty much the same:
    FC 3-4
    CC 0
    Ph 7.6-7.8
    TA 110
    CH 300-350
    CY 60ish
    The ph started spiking so I put MA I. The pool and took to 7.2
    TA went 90
    And oddly FC went to 6
    48 hours later FC is at 8, ph is back to 7.6 and TA is 100
    The only other change I made was I changed my de filter grids out and went from using 1 filter to two.
    Is there any reason my FC should spike like this? I haven't changed anything on my SWG or added chlorine.
    20' x 50' AG gunite pool (no idea on gallons) built a long time ago. DE Filter w/Hayward Pump. Well water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Odd Occurence
    Maybe the offline filter is full of leaves and twigs that the chlorine has been trying to oxidize?
    Jun 2015
    Bedford hills ny
    46
    Re: Odd Occurence
    I changed the de grids on it as well. So I went from one clean but beaten up de filter to two clean filters with new grids. Perplexing.
