Results 1 to 19 of 19
Thread: Converting salt to chlorine ; cloudy blue
    Jul 2015
    Brookville, pa
    10
    My pool chemistry is good but my pool water is a cloudy but blue. Ive noticed that my chlorine lvls will not stay up. My cya is 0
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Re: Converting salt to chlorine ; cloudy blue
    Welcome to TFP!
    What test kit are you using and can you post all test results. "Chemestry is good" does not give us the detail we need.
    Support the site
    Jul 2015
    Brookville, pa
    10
    Chlorine lvl 2 or 3 hours ago chlorine was good but now its 0. Ph is 7.4, alkalinity is 65, cya is 0
    Jul 2015
    Brookville, pa
    10
    Hth 6 way test kit
    May 2014
    Franklin, NC
    9,198
    You are loosing FC to two sources, UV from the sun because of no CYA and to whatever is growing in the water.
    You need a FAS-DPD test kit as you will need to SLAM the pool and your current kit will not test FC high enough. The most cost effective is the TF100 at TFTestkits.net and pick up the XL option as you will need quite a bit of reagent for the SLAM.
    Stop by Walmart and pick up a bottle of Stabilizer/CYA. Use Pool Math to calculate how much you will need to get your CYA to 30. Add that amount of CYA to a sock and either hang it in front of a return or place it in the skimmer. Do not just dump it in the skimmer.
    Please add your pool details to your signature so we know what pool we are dealing with.
    Support the site
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    If your CYA is 0, your chemistry is *not* good. You're using up any chlorine you put in their either from sun burn off, or algae growing. Which would also explain the cloudy water. Algae is going to go full-bloom soon if you don't get some CYA (Stabilizer) and chlorine in there.
    What are you using to chlorinate your pool? What are you using to test your water? Have you read Pool School at all?
    Jul 2015
    Brookville, pa
    10
    I use bleach
    Jan 2012
    7,373
    Ok then, how come no CYA?
    If by any odd chance you previously used stabilized pucks in some sort of floater, and had some laying about, you could use them for *a while* to get your CYA up. Or you can do it faster by hitting up the local Wallyworld or Lowes and picking up a 4# canister of "Pool Stabilizer" or it might say conditioner. Just check the ingredients for it to say cyanuric acid. That will help hold your chlorine in the water longer.
    Now lets discuss your testing kit...TF100 kit comes from TFTestkits.net or the Taylor 2006 kit from Amazon or TFTestkits.net, and on rare occasion from a pool store. Those two kits alone are the ones we recommend most. They'll test everything, properly, by using drop tests. MUCH more accurate than strips or pool store tests.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Without any CYA your pool will not hold any chlorine level. When chlorine level goes too low algae blooms. You need to go to Pool School (the button at the upper right of this page) and can learn how this works.
    chiefwej
    Jul 2015
    Brookville, pa
    10
    When i raise my cya will it clear my water up?
    May 2014
    Franklin, NC
    9,198
    Quote Originally Posted by nbpiam135 View Post
    Sent from my SM-G860P using Tapatalk
    No, when you raise your CYA you will not loose all of your chlorine to the Sun within an hour or two. Without CYA that is what happens, the chlorine is burned off quickly and with no chlorine in the water bad things have the opportunity to grow.
    You need:
    CYA to 30
    FAS-DPD test kit
    SLAM your pool to kill the stuff growing and clouding the water.
    Support the site
    Jul 2015
    Brookville, pa
    10
    Is my pool safe to swim in?
    Jul 2015
    Brookville, pa
    10
    I put two of those chlorine tabs in my skimmer last night and my chlorine was very high. So i am guessing since its going to be another sunny one today the chlorine will be gone shortly. The pool is still a cloudy blue white cant see bottom. Its clean as far as i know other than the cloudy and the lack of cya.
    Sep 2009
    Frederick County, MD
    185
    To me (and everyone else here), your pool is not safe to swim in if you cannot see the bottom. You are 7 posts in and seem to be ignoring (or not responding to) the advice of at least 3 experienced pool people who are suggesting stabilizer / chlorine / a good test kit (not strips) / pool school.
    This is something you can remedy pretty fast if you get in front of it.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    Jul 2015
    Brookville, pa
    10
    Sorry, i failed to update the forume, test kit is in the mail, the stabilizer is too.
    Sep 2009
    185
    Tremendous!
    Jim
    Jul 2015
    Brookville, pa
    10
    Why i asked if it was safe was hoping to at least wade into it tonight. Summer heat is beating on us. Haha
    Jul 2015
    Brookville, pa
    10
    Thanks for all that has helped. I will update when the stabilizer and kit comes in
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Welcome to the forum.
    Your main problem is knowledge. I recognize this because I started with none. We know you have a knowledge problem based on your statements above. The members above have given you a Band-Aid to put on the immediate problem. You need to learn how to stop cutting yourself. To do so, go to pool school at the top of this page and start reading. Once you read, understand, and apply the principles here you will never again say my chemistry is good but I have no FC or CYA and can't figure out why the water is cloudy.
    I got home last night after being gone for two weeks during which time nobody even looked at my pool. While not recommended, my SWG pool was still crystal clear (can easily make out the head pattern on the small drain cover screws in the deep end) and the chemistry was great although it did need a little acid. I've only been at this less than a year and have never owned a pool until now. This will be easy for you as well once you have the knowledge freely given here.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
