Thread: Testing CYA Taylor Kit - problems with the read
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    I understand the instructions about putting drops in until you don't see the black dot. But . . . does 'not seeing the black dot' mean that it is really hard to see it or absolutely cannot see it. Because if you try real real hard, you can still kind of see it. This absolutely cannot see it and barely can see it is the difference between 30 and 60.
    Any tips or help is greatly appreciated.
    25,000 IG plaster pool. DE Pentair 60 gallons. Hayward pump with Single speed AO Smith 2.4 hp motor. Pool installed probably 20 yrs ago. Taylor water tesing kit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Testing CYA Taylor Kit - problems with the read
    you can not see it at all so 60 cya
    and you thought it was a hard one
    j_m_min's Avatar
    Feb 2015
    Houston, TX
    47
    so not see it at all means more water, so this means 30 cya. Means I need to add more cya.
