Thread: Valve Types
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    Valve Types
    I did an admittedly brief search but didn't find much. My question is what type of valve is the standard Jandy diverter valve? Is it simply a ball valve just like the ball valves you can get at Lowes? The reason I ask is that my builder used what I'll call the "standard" Jandy type diverter valve for all my equipment at the pad. For whatever reason on my two lion head fountains he chose to put a ball valve at the back of the column that each lion is mounted on. The purpose of the ball valves on the lions is to balance the flow going to each one. In my experience with aquariums ball valves are great for off/on but very poor at regulating flow. On an aquarium I've always used a globe or gate valve for precise flow control. I thought I might replace these ball valves with Jandy valves but those seem to behave an awful lot like the standard Lowes ball valve. What would work best for precise control of the flow?
    IG 13,000 gal, WetEdge Prism Matrix Indigo Blue, Hayward C4030 cartridge filter, Hayward Ecostar VS main pump, Hayward Tristar VS feature pump, Hayward OmniLogic, Hayward Sense & Dispense (pH only), Stenner 45MPHP22 bleach, Hayward H400FDN Heater, Hayward Color UCL lights, Pentair LED Bubblers. TF-100 XL test kit. Test Results. Build Thread.
    22,553
    Re: Valve Types
    Jandy type valves are rotary gate valves, the ball valves are better at control than the Jandy type valves are. Now, I like the Jandy type valves better in most cases because they are full port valves, so they have less head loss when full open than the ball valves.
    38,520
    Re: Valve Types
    Ball valves also tend to get stiff and hard to turn and then the handle breaks off. The Jandy-type have lifetime warranty and can be rebuilt.
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    Re: Valve Types
    Thanks for the info.
