Thread: Solar Cover Stick
    Mar 2008
    Roseville,Ca
    30
    Solar Cover Stick
    Has anyone here ever use the Solar Cover Stick? I was looking into gettting one but would like some actual user input.I currently have Solar Sun Rings but they are a pain to use.Thanks everyone in advance.
    10,500 gal Gunite,Imperial White River Rok,1.5hp Pentair Whisperflo,320sqft Clean & Clear,Intellichlor 40 SWG,EasyTouch w/Remote,Pentair Pool Shark Sweep(suction side),Jandy AE2000 Heat Pump & 8mil Solar Blanket,SAM Light,18in Caribean Shelf,6 & 4 ft Benches
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Solar Cover Stick
    Looks kinda interesting. Wouldn't mind something like that, if I had the space for it. How much does it run?
    mas985's Avatar
    Pleasanton, CA
    11,741
    I use the solar roller which I think is what you are talking about. It works fairly well for me since I didn't have room for a true roller. It is a bit more difficult to use than a standard roller but it allows easy removal of the cover and to put it out of the way. Roll up is easier than unrolling but overall not too difficult.
    Mark
