Results 1 to 19 of 19
Thread: Chlorine Smell in Salt Water Pool
    Jul 2015
    Greenville, SC
    19
    Hello!
    I have a very basic, new pool owner question ... Should there be any chlorine smell at all in a salt water pool? *I know my SWG produces a small amount of chlorine each day. But this is a somewhat strong chlorine smell.* I've taken the pool water to be tested at our local pool store and the owner said this is normal. However, I installed a salt water pool because I didn't want to smell chlorine.
    Here are the readings from the pool store yesterday ...
    FC 3
    TC 3
    pH 7.8
    TA 75
    CH 140
    CYA 30
    Salt 4000
    PLEASE talk in basic terms to me as I am such a newbie!!! PLEASE
    16x36 IG Vinyl (25k gallons), Pentair Sand Dollar Filter SD60, Intellichlor IC40 SWG, Intelliflo Superflo VS Pump, Polaris 360 Cleaner
    Jul 2015
    Anrews/Texas
    50
    Re: Chlorine Smell in Salt Water Pool
    your chlorine smell is coming from the presence of CC, I would think you need to SLAM i believe is the term used here to kill whatever your chlorine is trying to kill and then the CC will go back to 0 and the smell will go away
    EDIT: and a salt water pool is still a chlorine pool as you mentioned. It just produces chlorine gas from the salt in the water instead of you adding the chlorine manually
    Intex 20' x 52" Ultra frame pool w/ 1,600-Gallon sand filter.
    Jun 2015
    Raleigh
    357
    We don't trust pool store tests. As above, it's very likely that you have CC which is what generates the chlorine smell. I have a SWG and FC of as high as 8 and no smell whatsoever.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    May 2013
    Bay City, Michigan
    283
    The chlorine smell is produced by the chlorine doing its job.
    If this chlorine smell was noticed after the pool was getting a lot of use that could be expected as it's oxidizing all the bather waste. If it's all the time, you could be battling algae and keeping enough chlorine to keep it from getting out of hand but not enough chlorine to eliminate it.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Jan 2012
    'burbs of Augusta, Georgia
    7,329
    High chlorine smells mean that your chlorine is overwhelmed dealing with chloramines. Check your tests. Hows the water look?
    Jul 2015
    Greenville, SC
    19
    The water is clear.
    Jul 2015
    Greenville, SC
    19
    Y'all really know your pool stuff!
    I'm guessing I should invest in the TF-100 test kit? I keep seeing that on this forum ...
    Meanwhile, is there a formula to figure out CC? Maybe I've missed those instructions on this site.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    The TF-100 can test for CC after you do the Free Chlorine test.
    Dolphin E10 Cleaning Robot.
    May 2015
    Chickasha, OK
    184
    TC (Total Chlorine) = FC (Free Chlorine) + CC (Combined Chloramines)
    I see your pool store test results show TC = FC, which would suggest your CC = 0. However, because pool store tests are notoriously unreliable, we can't be sure whether that's actually the case. If you're bored one day, take 2 or 3 different samples at the same time and drop each one off at a different pool store. Or, better yet, take those 2 or 3 samples to one pool store and have them test them all.
    This is why the foundation of TFP is testing your own water with one of the recommended test kits; that way we are all speaking the same language and we can all help with recommendations if you have difficulties with the tests.
    The TF-100 and Taylor K-2006 are both great test kits -- the TF-100 has more reagents (chemicals used to test the various aspects of water chemistry), so it ends up being a better value, IMO.
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    Jul 2015
    Greenville, SC
    19
    **the chlorine smell is gone**
    I received my TF-100 Test Kit today and have already put it to use!
    Here are my results ...
    pH 7.5
    TA 70
    FC 11
    CC 0
    TC 11
    CYA 40
    CH 250
    My SWG was running at 80%. I just adjusted it down to 68%.
    Please advise on what else I should do!
    Thank you!!!
    Mar 2007
    San Rafael, CA USA
    12,082
    Isn't it amazing how the pool store got an FC of 3 ppm but you measure 11 ppm? Are you using a 10 ml water sample and it took 22 drops to get the pink/red to turn clear?
    In your case, you probably were smelling chlorine because the level was pretty high. Still not at SLAM levels, but over 5 times higher than needed for an SWG with your current CYA level.
    You are doing the right thing by turning down your SWG. I'd lower it more probably to around 40% which would probably have the FC drop over time to around half so around 5-6 ppm. Then you can consider raising your CYA level if you want your SWG to last longer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Numbers look good!
    You can add your pool info to your sig, more here, Pool School - Getting Started
    Jul 2015
    Greenville, SC
    19
    I did use a 10ml bottle and it took 22 drops!
    Should I add any stabilizer???
    Mar 2007
    San Rafael, CA USA
    12,082
    If your pool is in full sunlight most of the day, then you could add stabilizer to get the CYA higher so that you'd be able to turn down your SWG even more, but if you want to wait on doing that later after you've got your FC settled down, that would be fine. You'll at least then be able to see what your normal SWG setting is for a minimum of at least 2 ppm FC with 40 ppm CYA.
    Jul 2015
    Greenville, SC
    19
    Thank you so much!
    Our pool is in full sunlight all day..no shade at all.
    I'm going to adjust the SWG and recheck for the next couple of days and see what happens.
    Thanks again!
    May 2015
    spring hill, FL
    40
    I have a chlorine pool and never smell chlorine. Just saying =)
    12k in ground, 14x28 sports pool, concrete/plaster/diamond brite, uncovered
    Waterway 1.5hp pump, waterway 150sqft cartridge filter, auto chlorinator, on city water, Zodiac MX8
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    I'm going to chime in on the smell question because my water sometimes more or less smells like chlorine as well. I noticed my tap water also kind of has the same smell. I can't tell you the exact conditions that the smell is better or worse but I've never had algae and my numbers rock. I haven't smelled any odor lately but in the spring it was kind gross smelling. Take a good strong whiff of your tap water.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I have a SWCG also, I have been working on getting my FC dialed in. If I notice a smell of CC in the morning I look for critters in the skimmer or leaves and stuff on the bottom.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    Greenville, SC
    19
    The chlorine smell is gone now! But the pool store lady told me I SHOULD smell a little chlorine 😝 Thank goodness for this site!!!! I knew she was wrong! lol
    That's a great point!
