Results 1 to 10 of 10
Thread: Replacing fallen tiles
    Jun 2015
    Lexington, NC
    123
    Now that my SLAM is over, and mechanical failures seem to be resolved I wanted to move onto another "to do"
    A good chunk of the waterline tiles have come off (before I bought the house), I retrieved 14 or so in-tact from the bottom of the pool and have a stack of unused tile in my garage. Simple, square bathroom like tile.
    Is there anyway to reattach the missing tiles without lowering the waterline? I'm not worried about it looking perfect as the missing section is an area you don't see unless you're in the pool, and there's no discernible leakage, but would like to at least reattach the tiles.
    Any thoughts here?
    ~30kgal in-ground concrete
    Hayward S-240 300lb sand filter
    Hayward 1HP pump
    Jun 2015
    Lexington, NC
    123
    Re: Replacing fallen tiles
    Anyone? Or did I end up in the wrong subforum?
    Hayward 1HP pump
    Sep 2013
    Charleston, SC
    537
    Congrats on completing the SLAM! I am sorry nobody has responded. I have no expertise in this area, but hopefully someone else will chime in that does.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Jun 2011
    Carlsbad, NM
    172
    Lower the water to a few inches below the tile. Scrape or grind off the original thinset. Install with any quality modified thinset, or a standard thinset with acrylic polymer instead or water. (that's I what I do). Use sanded grout for 1/8" + grout lines, unsanded for smaller. Nothing different from tiling a shower.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Jun 2015
    Lexington, NC
    123
    So the short answer here is there's no way to do it without lowering water level?
    Hayward 1HP pump
    Apr 2013
    Sacramento, CA
    2,769
    You need to lower the water. Sorry.
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by mackguy View Post
    You can certainly try anything you want---it's gonna be a mess either way, since when you scrape off the old adhesive, you'll end up with much of it in your water...without the tile bonding surface being clean and dry to begin with, you're really just asking for those tiles to come off again, and sooner than it took the first time. For what it's worth, taking the water down a couple inches below the tile line shouldn't take long, and shouldn't be a ton of water...also should not be a water table issue, though you will need to shut off your skimmers and only draw from the main drain if you have one since they will draw air if you don't.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Jun 2015
    Lexington, NC
    123
    I'll have to get some pictures later to show what I'm dealing with. I was hoping one of the underwater type epoxies would work.
    Sounds like maybe a winter project..
    Hayward 1HP pump
    Jun 2015
    Lexington, NC
    123
    Here we go
    Hayward 1HP pump
    Apr 2013
    Sacramento, CA
    2,769
    You want to drop the water level down a few inches -- remove all the tiles and clean up the concrete. Then you need to put some grout in those cracks so you have a clean surface to apply the thinset.
    My bet would be this is a five to seven year solution at best -- I suspect expansion and contraction of the deck will affect the tiles and limit your tile life.
