Results 1 to 9 of 9
Thread: New Hayward skimmer arrived!
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Question New Hayward skimmer arrived!
    Would appreciate your advice, tips, & tricks for installing the Hayward skimmer onto my Intex Ultra Frame pool. Still waiting for the Intex hose to arrive. Here's how I'd like to configure the installation so that I can keep the original intake to the sand filter functional. On the sand filter where pool water enters the pump, I want to create a t-connector that would accommodate hoses for the intake and the skimmer. Does this sound logical?
    Intex Rectangular AG Ultra Frame Pool Set, 24' x 12' x 52" (8403 gal, well water)
    Intex Krystal Clear Saltwater System model number: 28663EG/54601EG
    Intex sand filter pump, 120V 1,600gph with GFCI
    Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: New Hayward skimmer arrived!
    You're thinking of keeping the original intake and just T'ing it with the new skimmer ?? That shouldn't be a problem.
    Solar Blanket, Well Water, Borax Added. 76
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    I did that with mine. Its hard plumbed with pvc then a "T" off each side there is a valve connected to hose. To be quite honest since I put on the skimmer I rarely use the original...
    Take your time on the skimmer. Plan, review plan, prepare tools, install. That simple....
    Cheers,
    Rob
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    May 2012
    Las Vegas, NV
    92
    It help so when you want to clean the skimmer you close it and open the original intake without turning off the pump.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Thanks for your feedback yes, just want to keep existing hoses & add a t this year. Next year,me will do the hard plumbing. As for the Hayward skimmer, it is a daunting task! I want to keep the butterfly gasket in tact, so I'm going to use a technique I came across somewhere on TFP where the gasket is installed on one side then the skimmer is attached, holes drilled. Then the cutout is made, with partial disassembly of skimmer so the gasket can be installed properly.
    Quote Originally Posted by latin_racer View Post
    Exactly!
    May 2012
    Las Vegas, NV
    92
    I used 1 1/2 PVC and Flex PVC. The PVC thread here helped with the setup. I used Red hot blue glue and purple primer.
    Shop Christy's 8 fl oz PVC Cement at Lowes.com
    Just take your time and measure. I had to redo part of the PVC going out as I had a few leaks next to the fountain.
    For the Hayward skimmer I cut the butterfly and ended up with minor leaks on the side. I used clear window silicon on the edge of the skimmer and no leaks whatsoever. It has been weeks with no sign of any leak.
    K-2006 TEST KIT
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Oh wow, your setup is perfect! Thanks for sharing the pictures
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Is that available at the orange or blue big box? And where did you get your valves?
    Intex 18' x 52" AG with Sand Filter Pump & SWG (Model ECO15110) about 7,600 gallons tested with a K-2006-SALT.
    May 2012
    Las Vegas, NV
    92
    Got the valve from lowes it was cheaper instead of homedepot. It will be right across from all the PVC adapters.
    orange? Blue big box?
    Quote Originally Posted by Idigress View Post
    Forgot to mention that it's perfect when you vacuum. You can turn on the intake valve and close the skimmer while inside the pool instead of getting out to shut the pump off.
    K-2006 TEST KIT
