Thread: freah water no chemicals
    Jul 2015
    harlingen,tx
    4
    Cool freah water no chemicals
    Ok so after my intex ..turned into the spawn of evil seems like I've been working on my pool more than being in it. Isn't a pool suppose to be fun seriously thinking of getting rid of it... I need to put the chemicals. Question how many gallons,does my pool hold its a intex ultra frame 20x52 for some,reason I can't remember from previous years think I'm going into pool shock.so if anyone can tell me how to keep this water crystal clear I might be able too forgive myself for screwing up .its going to be over a hundred out today can I put shock in now,do I wait till this evening .please help I don't want to lose my beautiful water please help. Wont water in a pool without chemicals great algae. Texas is just too hot need help
    Sandra
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: freah water no chemicals
    Hello Sandra,
    Welcome.
    Yes you need chlorine (bleach) and stabilizer right away.
    How do you plan to test the water so you can accurately maintain your pool?
    Have you been to Pool School yet?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2015
    harlingen,tx
    4
    Idk and I don't know how much chlorine too put my pool .i have no idea how much I don't have a test kit .what f I just dump 2 bags of chlorine and the poo school. Thing has a amount already idk how much water it has
    Sandra
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    There's a calculator at the bottom of the pool math page where you put in your pool dimensions and it will tell you how many gallons it holds. Your 20'x52" holds 10000 gallons.
    Just dumping stuff randomly in your pool is not the TFP method. We rely on accurate testing and only adding exactly what your pool needs.
    Start by reading Pool School - TFP Home Page
    Them go to http://www.troublefreepool.com/calc.html and put in 10000 as your size. Set your current CYA to 0 with a goal of 30, and your FC to 0 with a goal of 4, and add what it tells you to add in stabilizer and bleach.
    You'll also need to test your pH somehow and put it in as your current level and target 7.2-7.6. Then add either muriatic acid or borax to get it into that range.
    Everything you need is available at WalMart, except for perhaps the stabilizer (cyanuric acid, CYA). You might have to go to a pool store for that, but don't let them sell you ANYTHING else.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jan 2012
    'burbs of Augusta, Georgia
    7,296
    If you're truly interested in keeping your pool healthy and swim ready, you need to put forth the effort to learn how big your pool is (how many gallons?) and what your test results are.
    It will take minutes to go to TFTestkits.net and order a test kit, either a Taylor's K-2006 or the TF-100. Then about one or two tests will save you all the money you won't be spending on unnecessary chemicals at the pool store. The test kit pays for itself really.
    And you need to read a little in Pool School to learn which chemicals you do want to use- household bleach is one most commonly used to raise chlorine levels. But you also need a little stabilizer to buffer that chlorine from your hot Tejas sun.
    Make the effort=Reap the rewards of a sparkling clean pool with clear healthy water
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Sandra,
    This is my first year following the TFP method. It works. Its cheaper by a long shot and these people on this forum are wonderful. Do what they tell you, read up yourself and you will find a joy in having a pool that is unbelievable. If I can do it, you can too!
    Rob
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
