Thread: Regular testing, how often?
    Mar 2015
    Las Vegas NV
    460
    I thought this information was posted in one of the sticky's explaining how to do each test but I don't see it and my search-fu seems to be weak this morning. How often should I run each test. For example in my 5 - 6 week old pool I've been testing cholorine daily, pH every other day CYA once (will test again this weekend) and the other tests rather randomly. Is there a guide as to how often to run each test? I apologize if this is clearly posted somewhere, I can't find it.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Regular testing, how often?
    Until you learn how your pool reacts, I would recommend testing as follows.
    FC, use the OTO test daily, use the FAS-DPD weekly. If the OTO shows low FC, then use the FAS-DPD to see if CC's are high and go from there.
    pH - daily until you learn your pool personality, then adjust as you see fit
    CH, TA, and CYA, monthly
    Divin Dave,
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Personally I test FC and CC everyday. In a newer pool you should find your sweet spot with PH TA and CYA. for instance I can go a few days on my PH because it stays at 7.3 -7.4. CYA every week or so since you only lose some with adding water and splash out. If I notice my FC isn't holding as well I check CYA.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is the link from Pool School.
    Mar 2015
    Las Vegas NV
    460
    Thanks guys!
