Thread: Stenner Pump Tube Life
    Nov 2013
    Fort Worth, TX
    112
    Out by my pool equipment last night and noticed the ground was wet. The Stenner pump was running and bleach was leaking out of it. I had a spare tube and had it replaced in under 10 minutes.
    I just installed this pump last fall, so the tube failed well short of one year. Is this typical? At one point the pump likely ran for a few days with an empty bleach container. Could this have shortened the life of the tube?
    How long do your tubes last?
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    22,539
    Re: Stenner Pump Tube Life
    I generally replace the pump tube once a year, but have had them last two years. Running it dry really doesn't hurt them, but I don't like doing it just because I was taught that you should never run anything dry.
    If it's less than a year old I'd call Stenner and see what they have to say.
