Thread: Do I need a return eyeball?
    kevin11's Avatar
    May 2015
    Northeast,Alabama
    50
    I have been running it without the eyeball. That's the way it was when I bought the house last year. I went to the pool store and bought one they had. I believe it's a 3/4" opening. Filter pressure starts at 15psi clean and when I installed the eyeball it jumped up to 20psi. The water looked like a wave pool with the eyeball installed. I have 1 skimmer and 1 return. Is the jump in psi bad for the filter? What would be the best way to increase my circulation and direct surface debris to the skimmer. I see they make a 1" eyeball that would lower the psi a little.
    18x36 IG, Vinyl, 20K Gal., Sand Filter, 1HP pool pump, 3/4HP slide pump, Taylor k-2006.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Do I need a return eyeball?
    Yes a 1 inch eyeball will lower back pressure, but will also not provide as much directed flow as the 3/4 inch, its performance will be about half way between no eyeball and the 3/4 inch you have now (plus allow directing flow direction). Since eyeballs are cheap it is worth trying the 1 inch to see if it gives you enough flow, otherwise stick with the 3/4 inch.
    kevin11's Avatar
    May 2015
    Northeast,Alabama
    50
    So the jump in pressure on the filter is okay? I'll try the 1".
    Thanks!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    You'll be fine. I think filters are good up to 60 PSI or so!
