Thread: Intex 2150 GPH Saltwater System & Sand Filter Pump CG 28679 low water flow error 90
    Jul 2015
    West Covina, CA
    1
    Unhappy Intex 2150 GPH Saltwater System & Sand Filter Pump CG 28679 low water flow error 90
    We purchased this Intex Saltwater & Sand filter pump for our above ground pool a month ago. It was working wonderful until a couple of days ago. I have done everything the manual instructs you to do when a low flow error pops up.
    • Clear any obstructions in the intake hose bydischarging it inside pool wall.
    • Tighten hose nuts, check hoses for damage,check pool water level.
    • Clean the pre-filtering basket more often.
    • Backwash filter.
    • Install the nozzle at the upper position of the
      pool inlet, and the strainer at the lower
      position of the pool outlet.
    • Remove about 1 of sand if necessary.
    • Remove any pool vacuuming device attached
      to the system line.
      It still does not clear error 90 and pump does not work HELP!!!
    screamingbeam
    Intex 24 ft x 12 ft x 52 inches with a Intex 129V Krystal Clearn Sand Filter Pump & Saltwater system CG-28679
    Casey's Avatar
    SW PA
    10,424
    Re: Intex 2150 GPH Saltwater System & Sand Filter Pump CG 28679 low water flow error
    Welcome to TFP.
    I'm bumping to see if we can get you some help and get up and running so you can enjoy your pool.
