Thread: Ic-40 and intelliflo
    Jul 2015
    O-H-I-O
    29
    Pairing these two together and want to see if there is an easy way to setup a run cycle on the pump and an output percent on the swg to get the desired chlorine to take advantage of the vs pump. Any advice would be helpful
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Ic-40 and intelliflo
    What I ended up doing is finally put a Timer to control the power to the SWG. It made my pump run time vs cell run time and chlorine output infinitely easier.
    Divin Dave,
    JoyfulNoise's Avatar
    May 2015
    13,202
    I have both but I have an IntelliTouch/EasyTouch control system. You need the Pentair automation for the IC line of SWGs or else your output power selection is limited to increments of 20%.
    Matt
    Jul 2015
    Dayton/Maryland
    83
    Same here. Only problem is the timer could be out sync with the pump timer.
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    It's all trial and error determined by your priorities. What is it you want most? Me, I'm a tight wad and have close neighbors so I only run my pump in the AM before the second tier PG&E kicks in. I need a couple of high speed hours for the infloor and then a few more making chlorine and skimming. Pump time is 5 hours per day at 70%. That keeps me at 6ppm, which is on the low side but I monitor closely and augment occasionally with bleach.
    First thing you need to find out is what the minimum speed you need to run to make chlorine. I'm at 1800 rpm, others on the forum are much less. Play with the buttons and test, test, test. You will find the sweet spot.
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,490
    My pump runs at 1100 rpm either 24x7 or 12x7 depending on if our trees are busy or really busy putting stuff in the pool. Pump is wired direct to the breaker. IC40 is wired to a time clock. Right now I think my SWG is running 8 hours at 60%. The time clock makes it easy to add or subtract an hour to dial in the FC. Makes the 20% increments a non-issue. If the pump isn't on for some reason the flow sensor will shut off the SWG. We left the SWG on 24x7 the first year and let the flow switch turn it off and on, worked fine that way too.
