Results 1 to 10 of 10
Thread: FAST CYA Dissolving method
    May 2014
    Ann Arbor Michigan
    42
    I am trying to balance my pool as well as keeping the chlorine that I have IN the pool. Today I added CYA...a.k.a stabilizer. being that I did not have a way to hang it off in the jets of the return...I figured I would just sit it in a bucket and let it dissolve over a week ...well that would give the weather time to suck the chlorine out.
    Long sorry short, I put 4lb of CYA in a home depot bucket got my drill and put a paint mixing paddle on it. I was able to dissolve 7 lbs of CYA in a matter of 45 min.
    Just thought I would share this finding
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: FAST CYA Dissolving method
    I'm not sure how that will actually work, if it will speed up the process?
    If you're in such a heck-fire hurry you could always just buy the liquid (about double the price). I think it will appear in the test in a day.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Interesting theory. I wonder if anyone has ever tried to boil CYA into water to see if that speeds things up?
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    I'm too lazy to hold a drill that long. I think I would have just dropped the sock in the skimmer. Or rigged up something like this.
    May 2014
    Ann Arbor Michigan
    42
    Actually...I went pretty fast. You put water in the bucket...mix for about 5 min...dump that saturated water into the skimmer...put fresh water in the remaining CYA at the bottom...mix with drill...repeat. I was just trying to figure out how to keep my Chlorine in the pool and not have the sun suck it up and keeping the pool balanced....
    Note: I just started up my pool within the past 4 days due to finishing a restoration.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    It also works to just knead a sock full of it. Work the sock a bit, dip it into the pool to rinse/re-saturate with pool water and knead it some more. If I do that for 5 min the sock is pretty much empty.
    Solar Blanket, Well Water, Borax Added. 68
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Quote Originally Posted by Kiss4aFrog View Post
    will any old sock work?
    Intex Rectangular AG Ultra Frame Pool Set, 24' x 12' x 52" (8403 gal, well water)
    Intex Krystal Clear Saltwater System model number: 28663EG/54601EG
    Intex sand filter pump, 120V 1,600gph with GFCI
    Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer
    Sep 2013
    Connecticut
    728
    Quote Originally Posted by Magus View Post
    Interesting - how many times do you think you refilled the bucket with water during the process? If it took about 5 minutes per round and you were at it for 45 minutes, that suggests about 45 gallons of water.
    I've read previous threads where people tried (and failed) to dissolve CYA in a 5 gallon bucket, even using very hot water. You seem to have found that it will dissolve, but that you need about ten times as much water as was reported in those other attempts. Thank you for reporting your findings!
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    30,419
    Even if you get it all dissolved, it does not seem to show up on the test any faster. It's frustrating but I think we all have to wait a few days to measure granular CYA.
    The Liquid measures instantly, but it costs more than twice as much.
    Mar 2013
    CT
    349
    Quote Originally Posted by Idigress View Post
    Only one you don't plan on wearing again...
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
