Thread: Does the extra drop affect CC results?
    Jul 2013
    North Canton, OH
    192
    I have read on here a couple times to keep adding R0871 during the FC test until you add a drop and get no color change, then subtract that drop. Won't that make your CC result low? It would seem that extra drop of R0871 would hang around unreacted and consume a little CC right when it is formed by the R003 addition. So I would think one could have 0.5 CC and regularly test at 0 instead.
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    domct203's Avatar
    Jun 2015
    CT
    3,595
    Re: Does the extra drop affect CC results?
    I found this interesting so I did a quick comparison last night while we were enjoying the pool. First FC/CC test I did the same as usual, one more drop after clear. CC 0.5ppm (very faint pink). Second test I stopped drops right at color change, CC 0.5ppm (very faint pink). I used the same water sample for both tests.
    I've done the same for the powder (1 vs 2 scoops) and at my FC levels I got the same result.
    Close enough for me.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    When testing for FC (and CC), add R0871 until the solution goes clear. That is your FC.
    It's testing for TA and CH is when you add drops until there is no further color change and then subtract the last drop.
    Quote Originally Posted by bkfamily1 View Post
    Divin Dave,
    domct203's Avatar
    Jun 2015
    CT
    3,595
    Quote Originally Posted by Divin Dave View Post
    Thanks for that clarification!
    Dom
    Dom - TFP Guide
