Results 1 to 8 of 8
Thread: safe chlorine levels for vinyl liner?
    Jul 2015
    ca
    5
    Hi,
    I have a vinyl liner pool. What is the highest chlorine level I can safely have without bleaching the liner at all? If I have a CYA level of 50, is it really fine to have a FC level of 6.0 constantly if I have a vinyl liner? Just want to make sure.
    I bought my house from my parents once they moved to a smaller house out of state to retire, and their last liner became pretty bleached compared to when they first got it. I have no idea what levels they kept the water at, but the when the new liner was installed they said it was pretty clearly bleached from too much chlorine at some point.
    Thanks for the help!
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: safe chlorine levels for vinyl liner?
    Do you have one of the recommended test kits?
    Take a look at this link
    http://www.troublefreepool.com/conte...art-slam-shock
    6 is totally safe for your CYA level
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    I too am curious as I'm moving from an in-ground gunite to an in-ground vinyl pool in another part of town.
    It's getting a new liner when I move in.
    Dolphin E10 Cleaning Robot.
    Jul 2015
    ca
    5
    Quote Originally Posted by Piolin View Post
    I'm using a PoolMaster testkit currently. It seems to be working well. I looked at the chart on this website to get ideal FC levels of 6 for CYA of 50, I just wanted to make sure it wouldn't harm the vinyl liner, or if instead maybe I should reduce my CYA and FC together.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I have a CYA of 70 using a SWG, and I may have FC from 5 to 8 depending of numbers of bather and sunshine all the time with no worries, I am more scare of algae!!!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    With a CYA of 50 you are safe all the way up to 20, so why would you think 6 is high? You should actually be shooting for 7 or so just to be safe that it doesn't get to 4 or lower.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    ca
    5
    I don't think it's high for the level of CYA, I was afraid it might be high because I have a vinyl liner and everywhere I read about "high" levels of chlorine bleaching vinyl liners, and the old liner was very bleached. I just don't know what a "high" level of chlorine is that would bleach the liner.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    oh, sorry. considering your CYA level. Over 20 would be getting close to too much. And even that would be okay for a little while, like if you were to ever try to fight Black Algae.
