Thread: Piping Pressure Test - Lost 2 psi in 7 Days
    May 2015
    Cape Coral, Florida
    43
    My pool is currently under construction and the piping under pressure testing. The testing started at 40 psi but over the last 7 days it has dropped down to 38 psi.
    Is this pressure drop acceptable? Should I be concerned?
    12,000 Gallon IGP 4.0-6.0 Deep, Pebble Tec, Heliocol Solar Heating, Solar Touch Controller, Pentair IntelliFlo VS Pump, Hayward C2000 Cartridge Filter, (3) Hayward LEDs, and AutoPilot 42,000 SWG
    30,414
    Re: Piping Pressure Test - Lost 2 psi in 7 Days
    I am not sure but I would bet it's OK. What does the PB say?
    May 2015
    Cape Coral, Florida
    43
    I just noticed the psi drop today and haven't heard back yet.
    Jul 2014
    New England - MA
    310
    likely more related to temperature change affecting pressure than losing water... a few psi change is normal.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    Feb 2015
    Santa Cruz, CA
    365
    Quote Originally Posted by spool View Post
    Sure someone from MA would say a few PSI is OK due to temperature change!!!
    Ours moved around quite a bit - plus the ones that were left for weeks changed a bit more than you are seeing.
    2015 Build Link: 15'x30' Rectangle (3'-6", 5', 4' depth) 14,000 Gallon Pool, Finish: Wet Edge Primera Stone Black Kona. TF-100 Test Kit, Dolphin DX5+S Robot, Jandy CL460 Filter, VS 2HP pump, AquaPure 1400 SWG, iAqualink2, Automatic Safety Cover. No Heater
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    Absolutely its temperature. I watched mine lose 2-3 at night and gain during the hot day times.
    102 Perimeter Freeform Pool, Rock Waterfall, Jandy Deck Jets, Depth 3'6" - 6', Stonescapes Aqua Blue Mini Pebble, Inpool Table, Rock Salt Decking, Jandy 2.0 Epump, Jandy 580 Cartridge Filter, Polaris 280 with booster pump, Jandy Power Center w/ PDA, Stenner Pump
    A country boy's pool build...Dean, Texas
