Thread: 1/2hp whisperflo vs 1hp superflow
    Jul 2014
    Los Angeles, Ca
    5
    Long time lurker first time poster here. I have a 18-20k in ground pool. No spa or water features. I'm replacing my old Century pump. My options are 1/2hp whisperflo or 1hp superior. I'm getting some plumbing work done and pool contractor recommends the whisper flo because of efficiency. My pool service guy recommends the superflo.
    So, I chose the superflo. Not installed yet.
    Did I make the right choice?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: 1/2hp whisperflo vs 1hp superflow
    Either one should be fine for your pool. The 1 hp will give more suction for manually vacuuming the pool, but that is about the only advantage.
    Love TFP? Become a
    TFP Supporter!
    Jul 2014
    Los Angeles, Ca
    5
    Thanks zea3. Since I'm not sure exactly how many gallons my pool holds, is there a range? It may be as much as 25k. I'm not at home to measure and do the math.
    May 2009
    Youngsville NC
    395
    You're probably close enough for sizing a pump. If you're looking to put chemicals in - then I'd want a much better guesstimate on gallons for the pool.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
