Thread: poly tank pool filtration system
    Jul 2015
    carson/ca
    1
    Hi,
    So I have a 8 ft deep poly plastic tank that I'd like to create an unconventional and temporary pool out of. Kind of like this one in Joshua Tree:
    augandeverythingafter.blogspot.com/2011/06/stock-tank-swimming-pools.html
    It is about 3000 gallons. I'd really appreciate any advice on a filtration system for the tank. Is there a way to install a pool pump without drilling any holes in the side of the tank? Would a pool pump and chlorine be sufficient to maintain it?
    Trish
    22,539
    Re: poly tank pool filtration system
    If it's deigned to hold water with an open top you could hook up a regular pool pump and filter system using a floating skimmer much like Intex uses and it would work.
    Do you have a picture of the particular tank you have?
