Results 1 to 12 of 12
Thread: Dolphin M4 Supreme
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    Dolphin M4 Supreme
    Anyone have one? Can you tell me what kind of plug they need? Electrician is coming Thursday and I need to make sure he puts the right one in.
    Cheers?
    Jeers?
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Dolphin M4 Supreme
    Regular 120v plug. Nothing special at all.
    Essential Links:
    Mar 2015
    rowlett, tx
    853
    Thanks so much
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    the M4 has very good reviews. Nice choice!
    Divin Dave,
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    It should be GFI protected, either at the panel or at the outlet itself. Outside outlets usually are.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by BobbyR View Post
    Especially near a pool. Won't hurt to double check with the Electrician on this Amanda, but he may say "Duuhhh, you think I didn't know that?" It's almost a given they will install a GFCI plug anywhere near the pool.
    Essential Links:
    Mar 2015
    rowlett, tx
    853
    Thanks yall!! It came today, and I can't wait to open it!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Here is a tip for when using a robot.
    If you have a thermometer in the water hanging on a string, take it out when running the robot. That sucker will climb up the wall and suck the string into the scurbbers and tracks and really screw things up. Its fixable, but a real pain to get the string out.
    Divin Dave,
    Mar 2015
    rowlett, tx
    853
    Ah thanks!!
    Where's the best place to purchase Dolphins?
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    120 outlet. Make sure you electrician will install a GFCI
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    I bought my dolphin m200 at my local pool store. If you buy online you will not get the warranty.
