Results 1 to 7 of 7
Thread: Intex hard plumbing
    Jul 2015
    Orlando, FL
    26
    Intex hard plumbing
    I know there is a bunch of threads on this but all I've found are products that are no longer carried by Lowes or Home Depot or the manufacturers have altered their designs (conduits, box adapters etc.).
    So, I currently have the smaller 1.25" hoses and want to upgrade to 1.5" (40mm) Intex hoses or 1.5" PVC. I just don't know what adapters to use? I want to use ball valves and a Hayward skimmer, along with my Intex pump and Intex SWG. I'd prefer to use flexible hoses instead of all rigid PVC to account for pool movement.
    This is a great link I found but I can't find the box adapter at Lowes or HD:
    PVC Plumbing Intex Pool Sand Filter | Above Ground Pool Advisor
    Anybody with updated info?
    25,000 gallon inground plaster
    K-2006 test kit
    Aug 2014
    Orange Park ,FL.
    6
    Re: Intex hard plumbing
    Lowes does carry the box adapter you can find it in the Electrical section its made by Carlon
    Jul 2015
    Orlando, FL
    26
    I've been unable to find it and read they modified their design.
    I keep going back and forth on how I want to do this. Now I'm thinking of using Hayward 1.5" returns and inlets, with 1.5" PVC 90deg elbows, then connecting the Intex hoses. How would I connect 40mm Intex hoses to PVC?
    K-2006 test kit
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by relliky2d View Post
    With this:
    http://www.amazon.com/gp/product/B00...DSF2FRRJB3H9RR
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2015
    Orlando, FL
    26
    Thought so, thanks!
    But then I won't be able to use my Intex vacuum, with a Hayward inlet..
    Main thing I want is elbows so the hoses don't hang on the return and inlets, dragging them down at an angle. Also want to maintain flexibility for liner movement.
    So if I use the 40mm Intex return and inlets, how would I attach PVC elbows and then back to Intex hoses? Lol this is confusing!
    K-2006 test kit
    Aug 2014
    Orange Park ,FL.
    6
    If you want to keep flexibility to your pump from hard PVC, you can use this adapt from Lowes item #188240 you will have to get some spare hoses and cut them in (2) sections then use this adapt. to connect to your PVC. I did this on my pump for flexibility and have never had a problem.
    Intex 16' X 48'' AGP 5000 Gallons 3000 gph sand filter
    Aug 2014
    Orange Park ,FL.
    6
    One more thing about these adapts. you will need a lot of Elbow Grease to put these adapts. on the Intex Hose because they are very tight. also use a stainless steel pipe clamp. PS forgot to mention you can cut the Intex Hoses to whatever length you need
