Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: No chlorine lots of algae HELP???
    Jul 2015
    York PA
    9
    Recently found this forum, and I have been trying to follow the TFPC method but I haven't been able to hold any chlroine in weeks. Took water to the guys at the pool store but they tell me I have nitrates and that I have to drain the pool. Do I really need to do this? It seems absurd that there wouldn't be something to fix this. Are they working with the water company? Do I just need to dump more Clorox?
    Jul 2015
    York PA
    9
    Re: No chlorine lots of algae HELP???
    Here are my test results
    FC - 0
    TC - 0
    TA - 100
    PH - 7.5
    CH - I think about 50
    Pool store also tested it, they said I have a lot of iron too?? I never have metal in my pool and it doesn't taste metallic.................
    Gilbert, AZ
    130
    I'm very new (and waiting for my test kit in the mail). You'll need to get a test kit and look at your various numbers (chlorine, ph, CYA, etc) and go from there. Once you get a baseline of those numbers you can SLAM your pool per the Pool School on this site.
    I'm currently waiting for my kit to start this, but that'll let you learn what levels your pool needs to be. Everyone here tells me to distrust pool stores, and I tend to finally agree now after dumping tons of random chemicals looking for the "magic bullet" that doesn't exist.
    Apr 2015
    Niskayuna, NY
    63
    It would be helpful to know what your CYA level is.
    18x36, 21,000 gallon, in-ground, vinyl, Pentair SWG, DE filter, Pentair 250K Heater, Taylor K-2006, Dolphin Triton
    Jul 2015
    York PA
    9
    Sorry, CYA is 40
    Aug 2013
    Arab, Alabama
    422
    Welcome to TFP! First thing we need to know is how did you get YOUR test results, from the pool store, test strips, Taylor kit, TF-100, or some other method?
    What does your water look like right now? What size is your pool? Is it vinyl or gunite? Is it in ground or above ground? Do you have a Salt Water Chlorine Generator? What kind of filter do you use?
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Jul 2015
    York PA
    9
    I used the TF-100. Pool store also tested but was slightly different results
    Aug 2013
    Arab, Alabama
    422
    Great! Stop getting anything tested at the pool store. Your results with the TF-100 are light years better in terms of accuracy. Put all of you pool info in your signature, as this well help us to help you. Start reading and then reread Pool School. For now just use bleach, muriatic acid, stabilizer, baking soda, borax, and rarely soda ash.
    Jul 2015
    York PA
    9
    I've been using most of those, but shouldn't I have chlroine by now? I've used so much bleach. What are nitrates exactly? Pool store told me I have 80 ppm but I don't really trust them
    Aug 2013
    Arab, Alabama
    422
    BTW, we love pictures! I would not worry about metals at this point...you may or may not have them. It is the only thing I would let the pool store test for me. Do not worry about nitrates or phosphates, as they are of no consequence in getting or keeping your pool crystal clear.
    Now tell me about your pool, size, filter, what the water currently looks like, etc...Yes you should have FC in the pool, but we cannot advise you until we know your specifics regarding the pool.
    Jul 2015
    York PA
    9
    I've been using about 4 gallons (1 case) of bleach per day for the past week. Should I be using more? What else should I do?
    The water is murky. Some algea on the walls. Water isn't green but more of a dirty aqua color.
    25,000 gallon Plaster pool. FNS Plus filter, WhisperFlo 1.5 HP pump, Nature² Mineral system. Ray-Vac cleaner
    Aug 2013
    Arab, Alabama
    422
    If you are at you pool right now do me a favor and add 2 jugs of bleach. Wait 30 minutes and test your FC. Post the results in this thread. This is assuming your FC is zero...you could have ammonia in your pool and it is consuming your FC at an alarming rate!
    We also need to know your CC levels as well...
    Jul 2015
    York PA
    9
    Alright will do!
    CC is also at 0
    Aug 2013
    Arab, Alabama
    422
    In the mean time what does your pool look like? Is it a swamp or very cloudy?
    Also, you need to stop using that Nature 2 thingamabob! I believe it adds metals to your water, copper specificlly...
    Aug 2014
    Northern IL
    4,615
    Is the Nature2 cartridge still in? I would empty it!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome poolguy!
    You may or may not have metals, but right now, it would be helpful to know your Cya level as well. One thing is certain you have a lot of Chlorine demand, but we can help you fix this no worries.
    Essential Links:
    Aug 2013
    Arab, Alabama
    422
    He tested his CYA at 40...
    Jul 2015
    York PA
    9
    Just tested, FC looks to be around 1.2. What would I do to kill ammonia??
    Aug 2013
    Arab, Alabama
    422
    Wow! You are going to need a ton of bleach! I would add 5 jugs of bleach wait 30 minutes and test your FC. You may need to do this several times to get your FC to hold at 16. You could also use cal hypo to do this because your CH is so low.
    How much bleach do you have on hand? You can also test your water for ammonia if you can get a test kit from a fish store.
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you have it, and Im not convinced you do, then you add chlorine until you kill it. Same as here. I would begin a SLAM on the pool right now. Begin adding bleach until you are able to reach and hold a residual of 16 PPM free Chlorine. No matter if there is Ammonia or not, this is what you must do.
    Essential Links:
