Thread: Muriatic Acid - Return Jet and Pool Equipment
    Jul 2015
    Phoenix
    72
    I've read about the recommended approach to adding MA on this forum... pouring it slowing in the deep end over a return jet with the pump running. My question is regarding the direction of the pool jet. My jets are currently pointed down. When I pour MA over it, I can't really see where the acid is picked up by the jet flow - no matter where I pour it around the jet. So, is it best to have it pointed in an upward direction such that is makes a steady flow on the surface of the water?
    Secondly, should I remove my vacuum from the pool prior to adding MA? Is it possible it could damage the vacuum, hose, etc. if it where to run right over freshly poured MA at the bottom of the pool?
    And finally, many have recommended brushing the walls and pool floor after adding MA... I'm guessing this will not hurt the brush, but not knowing any better, seems like it would eat nylon bristles.
    Thoughts?
    18K gal, 32' x 17' IG, pebble - Hayward SwimClear C5030 cartridge filter, 2HP Hayward pump, Hayward W530 leaf canister, Hayward AquaNaut 200 automatic pool cleaner, Taylor K-2006 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Muriatic Acid - Return Jet and Pool Equipment
    You really don't want the return flow breaking the water surface. Just shy of that is ok however. None of your equipment concerns going to be a problem.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    try about a 30 degree down angle when adding.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I use my returns to create a whirlpool so the skimmer can do it's job.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
