Emptying spa in the pool
What if the hot tub were chlorine? Whenever we changed our hot tubs water it was because it was getting 'greasy' or too hard to keep clean, I assume from the build up of body oils and contaminants etc... I guess the question is, if you're water is bad enough that you need to change it, why would you want to?
