Thread: Auto Fill Valve Replacement Advice
    Jun 2014
    Phoenix AZ
    74
    My pool has an older auto-fill mechanism. The fill supply is horizontal and you attach a auto-fill valve to it. This valve has a simple float attached to it.
    Its the older standard setup like so which I'm sure many of us have:
    Youtube Video of Auto-Fill Setup Same as Mine
    Currently I am using this exact valve:
    Float-Valve-Dial-Manufacturing-Inc
    It is crappy and doesn't work well.
    Some issues are that the you can't tighten the float to keep it in the "angle" that you want. I can tighten as much as possible but the float easily slips making the adjustment pointless. Also the value itself is leaky in the sense that it doesn't shut off very well due to the simple brass to brass mechanism.
    Can anyone recommend a good replacement?
    Thanks for any help!
    20K In-ground Pebbletec Pool with Spa and Waterfall; Pentair CCP520 Cartridge Filter; Paramount PCC2000 Infloor Cleaning System; Jandy Aqualink RS8 Automation
    Jun 2015
    Wildomar, California
    423
    Re: Auto Fill Valve Replacement Advice
    I can't dial up the company name, but that part is now all plastic and has a ss wing it to adjust the water level.
