Results 1 to 10 of 10
Thread: Shock adding shock to my pool need some advice
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    my FC 5
    PH 7.5
    TA 130
    CH 220
    CYA 60
    is it advisable I ad shock my pool. I'm using that poulcloud app it's telling me to add shock water is little cloudy. Wouldn't adding shock raise my chlorine levels?
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: Shock adding shock to my pool need some advice
    That depends on how high your Calcium Hardness level is. If you're already high, making it higher will just lead to scale formation and possibly mess up the plates in the SWG. If the water is cloudy and/or the CC level is above .5 (Another number you didn't share) then the SLAM process is called for. And for that, we recommend bleach. Adding lots of Cal-hypo can lead to cloudiness, which is your original complaint. Why make it worse?
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    What is CC Richard320 my chlorine level is 5 or above, my calcium hardness is at 220
    Richard320's Avatar
    Jan 2010
    19,034
    CC is combined chloramines. If you're using one of the recommended test kits, you can measure them. Pool School - ABCs of Pool Water Chemistry will define all these confusing terms we use.
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    My test kit don't measure CC
    Richard320's Avatar
    Jan 2010
    19,034
    Add-on: If CH is only 220, you can safely add that 20 ounces of Cal-hypo. That will get you to shock level, but to really and truly eliminate any algae caused cloudiness, you'll need to maintain that level of FC for at least a day or two, and that will put CH over the top.
    That said, if powdered Cal-hypo is what you have on hand, use it. Algae blooms are a lot easier to kill if you catch them early.
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Yep got 2 packs of these on hand. I used 1 pack
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    My TF 100 test kit comes in tomorrow
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I recommend you to take a look at this application for android, pool pal, is TFP friendly
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Quote Originally Posted by Piolin View Post
    Thanks I will surely check it out I use IOS. Thanks
