Stenner output connector moves around
It's normal. It's due to the peristaltic action of the pump. The tube stretches a little every time the roller squeezes it and it relaxes as it passes the outlet section. Since the pump tube connectors aren't fastened hard to the housing they can move around and it's not a problem.
OK, thanks. I won't worry about it then. Today will be my first day to run the pump. Set for 3 sessions of 20 min each via my Easy Touch.
