Thread: Intex pool filter question
    Jul 2015
    Bunker Hill,Il
    1
    I purchased a 24 x 52 Intex pool the filter that came with the pool I believe is way too small for the pool. Our pool is always very cloudy and I have to change filter every other day and it is coated with this white , chalky texture. I have taken our water to be tested at a pool store and our chemicals are correct. I have been re-searching getting a sand filter. If recommended what size do I need for the Intex 12,000 gallon pool ?
    30,421
    Re: Intex pool filter question
    Welcome to the forum. First, you need to identify the "white stuff" Your chemistry is not correct. If it was you wouldn't be having this problem, Since you do not have a test kit can you post the numbers the Pool Store gave you?
