Thread: Dark stains on plaster
    Jul 2012
    South Carolina
    48
    Hi there. I have rust colored stains that are on my plaster in deep end and on 1st step. See pics. Any ideas? Water sparkling clear.
    15 K gallons
    Gunnite
    Centurion Pump/Hayward Sand Filter
    Polaris 360 Robot
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,612
    Re: Dark stains on plaster
    Try rubbing a puck on one of them and let us know what happens. If that does not do anything crush up some vitamin C crushed up in a sock and rub that one them.
    Let us know what each one does or does not do.
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    the tiniest piece of steel will create a spot like those you have. I made the mistake once of hacksawing some metal closet shelving to length out on the patio. Guess what?
    Vitamin C will lift the stains. Just set a tablet on each for a few minutes.
    Jul 2012
    South Carolina
    48
    The vitamin c worked on the steps...easy enough!
    Assuming the ones in the deep end are the same, I've read about crushing the tablets and putting them in a stocking. How do I get the stocking to stay on the curved portion of the pool? How long does it typically take the vitamin c to work? As you can see from pics, I'm going to have to buy a lot to treat all the stains in the deep end. Cheapest place suggestions?
    15 K gallons
    Gunnite
    Polaris 360 Robot
    Jul 2012
    South Carolina
    48
    Ugggg....in reading more, I think I've caused these stains when I went on vacation. My Ph drifts up regularly, and I put extra chlorine since I'd be gone. Think this is the culprit? Ph has always raised rather quickly.
    15 K gallons
    Gunnite
    Polaris 360 Robot
    Mar 2007
    San Rafael, CA USA
    12,082
    If you add a lot of chlorine from hypochlorite, the pH will rise so yes that may have been the culprit. Before adding a lot of hypochlorite, lower the pH first. Also make sure you have enough metal sequestrant in the water. You could consider removing the metals from the water by using Metal Magic to try and capture it in the filter or by using CuLator to capture it in its bags in the skimmer.
