Results 1 to 15 of 15
Thread: burning eyes
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    burning eyes
    I checked my pool levels yesterday and they are the same as they are today. The children are complaining of burning eyes.
    TC 3.5
    FC 2
    CC 1.5
    PH 7.5
    ALK 120
    CYA the view tube is completely full, and I can still see the black dot clearly (done twice both days)
    Ch 50
    2017 bahama spa - serenity cove 82x82x39 stainless steel jets, 325 gallons,plasma ozone purification system,4kW heater, 2 pumps 6bhp each, acrylic surface TFtestKits TF-100 http://tftestkits.net.
    Orlando, FL
    690
    Re: burning eyes
    Burning eyes are usually the result of CC or PH. Can you post your combined chlorine number?
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Donldson's Avatar
    NW Ohio
    2,919
    Re: burning eyes
    With no CYA to buffer it an FC of 3.5 is going to be pretty harsh and my guess as the likely culprit.
    I see you had a CYA level of 50 in May, have you had to replace water since then?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    Re: burning eyes
    Quote Originally Posted by Donldson View Post
    Yes. We have had a lot of rain lately (1-2 inches) over the past 3 weeks.
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    Re: burning eyes
    Quote Originally Posted by f3justusc View Post
    Posted
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Re: burning eyes
    That CC number is worrisome..... It's 30% of your TC.
    If this was my pool I would add enough CYA per pool math to bring it to ~30ppm, and do an OCLT.
    FWIW- I keep my FC above 6ppm with a CYA of 40ppm and nobody complains of burning eyes. We have even gone in an hour after my evening dose where it is closer to 10-11ppm and still no complaints. My CC's are always <0.5ppm also.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Re: burning eyes
    I'll just double up on the lack of CYA not buffering the chlorine in the pool.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Aug 2013
    Arab, Alabama
    422
    Re: burning eyes
    Dom is speaking the truth!
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Jul 2015
    Burkburnett/TX
    57
    Re: burning eyes
    New here...so bear with me.
    The non-existant CYA is a problem and needs to be fixed or the pool won't maintain chlorine in the sun. But the CC at 1.5...isn't that indicative of something growing in the pool? IE...is a SLAM needed to clear up the stats after bringing up the CYA?
    Sean
    17X34 above ground painted concrete pool. 32" deep on the shallow end, 44" on the deep end. Sand pool filter.
    Jul 2013
    North Canton, OH
    192
    Re: burning eyes
    If you are using the pool and testing at the right time, you will always see CC. When the FC reacts with anything in the water, CC will be formed, then eventually broken down the rest of the way and disappear again. That is maybe oversimplified, but it is how I understand it. Someone please correct me if I am wrong. So CC is not necessarily a sign of a problem, but rather a sign of the chlorine doing its work.
    Now having said that, 1.5CC seems pretty high. So it may be a sign of a need to SLAM. But I would second Dom's suggestion of doing an OCLT to decide if a SLAM is needed.
    The low CYA does seem a likely culprit. However, even with CYA down at 20, shock level FC is 10. So unless your CYA is WAY down there, it may be something else. And if your CYA was 50 in May, it would seem like something unusual had to happen to drive it that low. Even if you drained or backflushed or vacuumed to waste or overflowed your pool enough to remove and replace a THIRD of your water (5000 gallons) TWICE it would still only get you from 50 to about 20. That is unless something happened like an algae bloom that consumed the CYA.
    The other thing I would be thinking about is pee. If anyone is peeing in the pool, it will eat your FC like crazy and produce significant CC pretty quickly. And the chloramines that are formed hang around a while and cause burning eyes and the stereotypical "chlorine pool smell." If that is what is going on, feed it enough chlorine to keep the FC up, and give the pool plenty of sunlight which helps break down the chloramines.
    But I would still follow the recommendation of Dom and others. Get your CYA up to a reasonable level. If that was the whole problem, that should fix it. If it does not, do an OCLT to see if you have something in the water that needs a SLAM. And if the CYA is good, the OCLT is good, and you are still having the burning issue, then I am thinking pee is the issue.
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: burning eyes
    I was always under the understanding if your CC was over 1. there is the need for a SLAM. That is one of the criteria to end a SLAM, CC under 1.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: burning eyes
    Quote Originally Posted by bkfamily1 View Post
    This is actually the only time you would expect to see CC in a well-maintained pool. I've tested the water with 6-7 adults and older kids in the pool. 0 CC several times. Urine is a different animal. It rapidly reacts with chlorine (FC) and forms CC compounds that don't break down as quickly as others.
    Get your CYA up and perform the OCLT as recommended.
    Isolated Spa - 345 Gallons
    Jul 2013
    North Canton, OH
    192
    Re: burning eyes
    Quote Originally Posted by PAGirl View Post
    PAGirl, I thought the same thing. But a few discussions on here led me to the understanding that the presence of CC in and of itself is not necessarily a sign of a need to SLAM. The real sign of a need to SLAM is the presence of something growing (organics) in the water. Two things consume FC - sunlight and organics. The OCLT eliminates the sunlight, so you only see the FC consumed by organics. So the OCLT is the best signal that there are indeed organics active in the water and the need to SLAM.
    Orlando, FL
    690
    Re: burning eyes
    Quote Originally Posted by wbowlin1 View Post
    Posted
    Sent from my SCH-I545 using Tapatalk
    I saw it after I posted. Sorry. You are in good hands!
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Re: burning eyes
    .........I see you had a CYA level of 50 in May, have you had to replace water since then?
    Are you absolutely certain your CYA of 50ppm was correct? 1-2" of rain in a pool your size shouldn't effect the CYA (or anything else) at all, well at least a measurable effect. I've done that a dozen times or so (rain, splashout, backwash, etc) this season and just now I'm bumping my CYA 10ppm to get back to 40-ish ppm for the first time this year. Adding water then draining does not have the same result as draining then adding water.
    Did you do an OCLT?
    Dom
    Dom - TFP Guide
