Thread: Non-Chlorine Shock
    Jul 2015
    Pittsford, NY
    32
    Non-Chlorine Shock
    When is the best time to use non-chlorine shock? I have a small amount of algae in my pool I'm trying to kill off, and just added two gallons of liquid chlorine. Once the liquid chlorine does it's job, would it be smart to use the non-chlorine shock to clear it up afterwards?
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Non-Chlorine Shock
    What would be smart is to continue using liquid chlorine to clear up and keep away any now and future algae.
    What is the ingredient in "non-chlorine shock" ?? Why would you want to use it over liquid chlorine?
    Jul 2015
    Pittsford, NY
    32
    I don't want to use it, necessarily, but the previous homeowner left me about 10 bags of it, so I figured I would use it if it had some use...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Be careful with that stuff. If it's Potassium Monopersulfate, it will mess up your chlorine test results unless you buy another reagent to neutralize it. https://www.taylortechnologies.com/C...P?ContentID=24
    JoyfulNoise's Avatar
    May 2015
    13,231
    Non-chlorine shock is typically MPS (or potassium monopersulfate). The thing to realize about MPS is that it is an oxidizer (although not as strong as chlorine) and it's not a very good sanitizer. It will also create false readings of both CC and FC (depending on what CC's are present in your pool) when you use your FAS-DPD test kit.
    So, at the end of the day, there is no need to use MPS shock if you have adequate chlorine around as it's likely to cause more problems than it will fix. As for what to do with it....would a local Pool Store take it from you in trade for some store credit?
    Matt
