Thread: Liquid solar??
    May 2015
    Monroe/NJ
    76
    Liquid solar??
    Anyone have any experience with these liquid solar products? They claim to help hold the heat in without the use of a pool cover. I am VERY SKEPTICAL to say the least but I am curious if anyone has ever used them and what they think of them....
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    Jun 2015
    Raleigh
    357
    Re: Liquid solar??
    They work on the principle of increasing surface tension so water doesn't evaporate as readily. Most of heat loss in a pool is due to evaporation. So they do help but it's hard to quantify how much.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,458
    Re: Liquid solar??
    I tried it for a week or so a few years ago. No measurable improvement. Installed solar panels. Those help a lot!
    38,254
    Re: Liquid solar??
    Many threads discuss these products. Basically any breeze and it does not seem to work well.
    DFW, TX
    24,458
    Re: Liquid solar??
    That's right, I forgot about the wind blowing it all to one side of the pool.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Liquid solar??
    It's supposed to spread across the pool just one molecule thick. I found it also ruined the seals on my electronic thermometers, so I couldn't really tell if it was working. I became concerned for what it might be doing to other equipment. I sure wouldn't recommend it. A solar cover works much better.
    chiefwej
