Thread: Polaris 360 ?
    Dec 2007
    NW Georgia
    56
    Polaris 360 ?
    My polaris does not want to stay in the shallow end. It makes one or to passes then heads straight back to the deep end. I pull it back to the shallow end and its back to the deep end. So has anyone else had this problem if so what do I need to do to correct it?
    41K L shape Vinyl IG, 2.0hp Jandy stealth pump, 300lb sand filter, Autopilot Dig-220 SC-60 cell, Dolphin Oasis Z5.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Polaris 360 ?
    If you take it out of the pool and turn one wheel by hand do the other two turn with it?
    Dec 2007
    NW Georgia
    56
    Re: Polaris 360 ?
    Yes
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Polaris 360 ?
    Is this a new problem or has it done this since it was installed? A few more things to check:
    Make sure the thrust jet is at 11:00 like so:
    Take off the head float and make sure there's no water in it.
    Make sure the hose floats are evenly spaced about 3' apart, with one right behind the backup valve.
    Check the RPM. Should be around 30.
