Thread: Tezt kits
    Tezt kits
    Does anyone know if Taylor k 2006 kit is worth buying having bit of trouble finding a tf100
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Tezt kits
    Hi, welcome to TFP!
    the tf 100 is available at TFTestkits.net and on the west coast at Pool Supplies, Spa Supplies and Parts
    Those are the only 2 places you can get the TF100
    the K2006 is a great test kit and lots of folks here use them. There is a version of it K2006C. The "C" version has larger quantities of test regents, which is nice, so that you dont have to order refills as often.
    Of the two, the TF100 is the best bang for the buck because the test regents you will use most are double that of what is contained in even the "C" version of the K2006.
    Hope this helps,
    Divin Dave,
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Tezt kits
    You should also look at the Taylor speedstir. It makes testing a LOT easier. If you want to make it even easier order the Sample Sizer water displacement tool. It makes it a breeze to size 10 and 25 ml samples.
    TFTestkits.net
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Tezt kits
    Quote Originally Posted by Divin Dave View Post
    Hi, welcome to TFP!
    Hope this helps,
    ^^^^^^^^^^What he said!
    Support the site
