Results 1 to 7 of 7
Thread: How to keep chlorine test crystal scooper dry?
    Jun 2015
    Mesa, AZ
    22
    Little detail question. We've had a Taylor 2006 test kit for a little while now and like it. But we've noticed that the little scooper for the crystals that you put in to tube for the first step of the free chlorine test gets wet in the container, even though we're careful to keep it dry when we use it. Other stuff that's in the kit gets wet (tubes for testing especially) and those get put back in the Taylor box, so I'm guessing that the presence of that moisture in a closed box is enough for water to be drawn to the little scoop, meaning we have to dry it off somehow each day before using it. So, just wondering how people handle this and any ideas of how to avoid this problem, as my understanding is you really don't want wetness around those crystals. Thanks!
    18k gallon in ground pool. Whisper flow pump, Pentair FNS 48 DE filter. Pool interior resurfaced with mini-pebble in May 2015. Kreepy Krawly Sand Shark Cleaner. Taylor 2006 test kit. Shade structure over shallow end of pool.
    Sep 2013
    Connecticut
    728
    Re: How to keep chlorine test crystal scooper dry?
    I make sure to rinse off the little scoop before putting it in its storage spot - it always seems to be dry next time I use it. Maybe it's powder residue on the scoop that attracts the moisture you are seeing.
    Normally I don't use the kit on a daily basis; however, even during a SLAM, when I was doing the FAS-DPD test multiple times daily, the scoop was dry in time for the next test.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Jun 2015
    Mesa, AZ
    22
    Sounds like an idea to try. I'll wash off the residue and see how that works. Thanks!
    Sep 2014
    Fort Lauderdale, FL
    146
    I keep my wet stuff outside the box until it's fully air dried.
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
    Aug 2014
    Northern IL
    4,615
    My scooper never gets wet. Do you stir with it or something? Sorry if I'm missing something here...
    domct203's Avatar
    Jun 2015
    CT
    3,584
    I rinse then wipe the scoop dry before I put it away, I test FC daily and the scoop is not discolored at all, it still looks brand new.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    30,419
    Cha-ching! Testing apparatus should be kept high and dry. Lot's of ways to do it
    Keep a little towel close by to give your stuff a cursory wipe is one way.
