Thread: The pump don't work 'cause the vandals took the handles
    Jul 2015
    Maplewood, Missouri
    1
    I have an INTEX 15110 pump. I am using it for the first time in two years. I have everything hooked up correctly. When I turn it on, it doesn't pump: it just makes a low humming sound and smells vaguely electrical. Is there anything I can do?
    Jun 2012
    western NY
    1,560
    Re: The pump don't work 'cause the vandals took the handles
    With the power unhooked, try to see if the impeller will spin free. Sounds like it is either bound up. It should spin freely and with a good spin keep going for a bit. There is a remote possibility that it could be a bad start capacitor, but usually when they are bad, you don't get the smell.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
