Thread: keeping the ladder to the slide clean
    Jul 2013
    North Canton, OH
    192
    any suggestions how to keep the ladder to the slide clean? algae tends to grow on the steps, I suppose since there is no "fresh" FC-laden water on them all the time - it also tends to grow under the slide near the bottom of the ladder where water tends to collect during use - I brush it off occasionally and spray it down with diluted 12% liquid - but it always comes back
    the slide is this style
    Thanks
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: keeping the ladder to the slide clean
    Is it because water collects on the steps in a small puddle at the toe of the step? If so, I'd drill some holes on that edge to allow water to pass through. Same for along the ground where you're getting algae. Create some holes for the water to pass through.
    Isolated Spa - 345 Gallons
    Jul 2013
    North Canton, OH
    192
    that is exactly what happens, JV - great suggestion - thanks
