Results 1 to 18 of 18
Thread: Help: I think my pool has cancer The dreaded Black Algae.
    Jul 2015
    Gilroy/CA
    21
    Hello All,
    I'm feeling a bit exhausted after my 1st SLAM to recover a 2 year neglected pool about 1 month ago. It was my fault as I was recovering from a medical issue and just let it go. The pool looked good after I followed the great advice on here. There were some stains at the deep end which looked like leaf/muck stains as they would not brush off even with a SS brush. OK, I can live with that as I can still enjoy my pool. There were some iron stains which I removed with an AA treatment more than 2 weeks ago. Thanks again to TFP. Now I am having a black algae problem. I tested it by scraping it off with my fingernail and spreading it onto a white paper, it was dark green . I have been keeping the FC at 5ppm since the SLAM. I also added PQ 60 before hand, bringing up the FC slowly after the AA treatment.
    So here we go again. I'm ready to SLAM again if it's not a lost cause. Here are my numbers:
    FC: 18
    CC: 0.4
    PH: 7.2
    TA: 110
    CH: 275
    CYA: 30
    Photo of suspected black algae
    https://www.dropbox.com/s/q34n70pp3j...38_33.jpg?dl=0
    My pool today after overnight SLAM. Pool was perfectly clear before start of slam.
    https://www.dropbox.com/s/chbbjn7mj0...3_174.jpg?dl=0
    TIA.
    Roger
    16000 Gallon Plaster pool, Tagleus 2 TA100 Sand Filter filled with Zeobrite media, 3/4 HP Sta-Rite pump, Dolphin Deluxe 4 Robot, BBB method, Taylor K2006 Test kit. Nothing to brag about here. Lifelong Student of Life. "If you know everything, you fail to learn anything." --not sure who said that--
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Help: I think my pool has cancer The dreaded Black Algae.
    Hello,
    Here's how to handle Black Algae. Pool School - Black Algae
    It's not so bad, I've got a couple of spots that I'm fighting also. Just try to keep up on it. Your stainless steel pool bush is your friend.
    Jul 2015
    Gilroy/CA
    21
    Quote Originally Posted by bobodaclown View Post
    Hello,
    I brushed it last night and I can still see it. I'm really scrubbing it hard and it still looks black. I'm going to pick up a smaller SS brush to increase the pressure. What I'm not sure about is the staining on the bottom at the deep end. You can see it on the second picture. I think I'll be looking like Popeye after this is over. Looks like I can back off the high FC when the water clears. I'm going to try and dive down and get a sample off the bottom. I hope the test is negative.
    30,432
    It looks like black algae to me, too. You cannot get rid of it overnight. It got there after a long period of neglect and it will take a long period to get rid of it.
    Keep you chlorine high and brush daily. You are uncovering it and exposing it to the chlorine. Your patience and steady brushing will eventually get rid of it.
    Jul 2015
    Gilroy/CA
    21
    When I brush, should I try to get all of the black off? This is my first rodeo and I'm not sure when enough brushing is enough for the current session. Should I keep up the mustard level shock or the lower green algae shock? Thanks all for the replies.
    Jul 2013
    North Canton, OH
    192
    one quick question - I see your light is out of the pool - great to have it out to be sure the niche is clean - could algae stay active on the back of the light while it is out of the water and come back when it is put back in later? should the light stay in the water during a SLAM?
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Jul 2015
    Gilroy/CA
    21
    Quote Originally Posted by bkfamily1 View Post
    My thinking on that one was to leave it out so I can scrub in there during the SLAM then take it apart and clean the heck out of it while it is out and soak it in a 5 gallon bucket with high levels of FC. I will put it back in when I'm sure I've won the battle. Seems like a good idea, but I'm definitely not an expert. If I'm doing something incorrectly, please call me on it. Thank you.
    Jul 2013
    North Canton, OH
    192
    garlic - I am no expert either, so take what I say with a grain of salt - note that I was not suggesting you mount it back in the niche - I agree scrubbing in the niche during the SLAM is a good idea - I was suggesting leaving it out of the niche but hanging down in the pool so any algae on the light is also killed during the SLAM
    Jul 2015
    Gilroy/CA
    21
    No offense taken or given, I was just explaining what I had planned. I think your idea may work better. It would probably be difficult to maintain the high FC in the bucket. I'm not really looking forward to all the scrubbing, but I'll do what I need to do. I appreciate your responses, please keep them coming.
    Thank you.
    Roger
    Jun 2015
    Phoenix, AZ
    73
    Quote Originally Posted by GarlicCity View Post
    then take it apart
    Unless the buld needs replacing, I wouldn't take it apart.
    Apr 2011
    Murrieta, CA
    2,360
    Black algae isn't a week of shocking process. You have to keep elevated levels and brush to expose the algae. If the surface is smooth it will come
    off easily. No need to go crazy taking everything apart.
    Jul 2015
    cordova
    13
    I'm no expert either, maybe you should vacuum and clean your filter?
    Jul 2015
    Gilroy/CA
    21
    Update: +36hrs
    Numbers:
    FC: 14 in AM added 1 gallon Cl to push it up during the heavy sun.
    CC: 0.2
    Approximate same location as picture #1 from original post:
    https://www.dropbox.com/s/4uqhr1ebqa...s%201.jpg?dl=0
    Pool as it is now, a little less green tint. This is after brushing:
    https://www.dropbox.com/s/554gnvmt10...l%201.jpg?dl=0
    This is what I'm calling Black Algae Ash. Looks like charcoal rubbed on surface. Not sure if this is a stain or active BA?
    https://www.dropbox.com/s/y6qrgu822b...s%202.jpg?dl=0
    I'm brushing vigorously in the morning and when I get home from work. It's a good workout.
    Filter is clean and my little friend (Pool robot) cleans/vacuums every day.
    Looking up if I can get a replacement gasket for pool light before I risk taking it apart.
    Here is a pic of the pool light. Not sure if that's calcium scale or etching, but wow. CLR?
    https://www.dropbox.com/s/yqcdodk2r0...x%202.jpg?dl=0
    Thank you all for your replies/help.
    Roger
    Jul 2015
    Gilroy/CA
    21
    Update +60 hrs for the sake of others who may encounter this enemy (BA).
    Numbers:
    FC: 14.5 Added 1 gallon Liquid Cl
    CC: 0.5 Using 10ml sample
    CYA: 30
    Brushing seems to be doing nothing to remove black "ash" in certain locations. See pic.
    https://www.dropbox.com/s/elftc8ttdg...l%202.jpg?dl=0
    Pool at +60 hrs
    https://www.dropbox.com/s/p1hvxdxlmw...0pool.jpg?dl=0
    Tried scrubbing some of the "black ash" off the side with trichlor puck: No difference.
    Will keep up the battle.
    Roger
    Jul 2015
    Gilroy/CA
    21
    Update +84 hrs.
    My numbers:
    FC: 10 Added 64oz, lowered target to 12ppm from 18ppm (mustard to green shock level).
    CC: 0
    PH: 7.7 (sample from previous day left out to dissipate high FC) Added MA to target of 7.2. Thought high PH causing iron to come out of solution.
    Back-washed filter, lot of material came out.
    Cleaned filter bag in my little friend (Dolphin Robot). Think of throwing it in the washer tonight. Filter bag that is.
    I'm starting to think that I'm having multiple problems simultaneously. The black "ash" seems to be remaining if not growing. I think the plaster is so rough that the black material is in the pores and I can't scrub it out. I did have a iron stain problem before this, which was cured with a AA treatment.
    https://www.dropbox.com/s/jwt7m8qf4n...h%201.jpg?dl=0
    Here is the pool:
    https://www.dropbox.com/s/fnq68nmddn...l%201.jpg?dl=0
    I placed a TriChlor puck on some stains in the deep end for 15 minutes. The clear spot to the right it appears to have lightened the stain. Where the puck is currently in the pic did not lighten the stain. I'm a little confused as both stains look the same.
    https://www.dropbox.com/s/k3p1yrrybs...k%206.jpg?dl=0
    Any help is greatly appreciated.
    Thanks for viewing,
    Roger
    Apr 2011
    Murrieta, CA
    2,360
    You're making great progress.
    Remember this part:
    After several days to a week, if the above procedures are not resulting in noticeable improvement, you may have to add the following step to the removal repertoire (and it’s no picnic):
    5. Rub a trichlor puck along all of the black algae-infested areas of the pool. This is best done immediately after brushing so the concentrated amount of chlorine can come in direct contact with the algae itself. Note that the acid in a trichlor puck can remove a thin layer of plaster which could result in slight discoloration. Therefore, this step should be performed only if steps 2-4 above are not resulting in a noticeable improvement after several days to a week.
    Unfortunately, the procedure for removing black algae does not lend itself to a standard regimen where you can make rote statements like “Brush your pool X number of times a day”, or “Hold FC at X level for this long” and expect the algae to go away in X number of days. Because every pool and black algae outbreak is different, you may need to vary the steps above in terms of frequency, mix, and intensity based on observation of progress. And remember to pack your POP (Pool Owner’s Patience/Persistence).
    Keep up the work.
    Jul 2015
    Gilroy/CA
    21
    Remember this part:
    Keep up the work.
    Thanks for the words of encouragement. At least I'm getting a good workout.
    Jul 2015
    Gilroy/CA
    21
    Update +108hrs.
    OCLT 25ml samples
    9:00pm 7/30/2015
    FC: 11.2
    CC: 0.4
    5:45 am 7/31/2015
    FC: 10.0
    CC: 0.4
    Looks like I'm almost there. Once I reach it, I will continue for an additional week. Water is crystal clear. It looks like my iron stains are back, but I will deal with that when I know the Black Algae is defeated. Tip for others fighting this who also have metals, retain a water sample to be tested for PH the next day. Just leave it out and the FC will dissipate on it's own. Just test it for FC before you test for PH. I let my PH get up to 7.8 before I thought of doing this.
    Pool at 108 hrs:
    https://www.dropbox.com/s/kndeum62ze...0pool.jpg?dl=0
    Black ash and/or iron stains?
    https://www.dropbox.com/s/vgc4z9ki0h...20ash.jpg?dl=0
    Thanks for viewing/responding.
    Roger
