Thread: Electrical Advice
    Jul 2015
    SHERWOOD
    2
    Electrical Advice
    We have a new Intex Bubble spa that we want to put on our covered patio here in Oregon. There is no suitable outlet and we need to use a short extension cord. What kind of cord (rating, color, etc?) should we use. We cannot hard wire it since this is a rental. It will be protected from damage, water, kids, and so on.
    Thanks for any help.
    22,551
    Re: Electrical Advice
    According to the manual it uses a minimum of 13 amps so you need a cord of at least 14ga wire or rated for at least 15 amps if it's going to be 25' or less. If it's more than that you need a 12ga cord. I wouldn't recommend an extension cord more than 50'
    Jul 2015
    SHERWOOD
    2
    Thanks for your quick reply. Is there any advantage to go with the higher gauge for the shorter cord?
    Thanks again.
    22,551
    There is, because there would be lower voltage drop with a larger cord. I always go with the largest cord I can find. Just FYI to anyone in the future, the larger the number, the smaller the size wire.
