Thread: Removing/Replacing rod from Hayward C1200 filter.
    Mar 2014
    Melbourne, FL
    4
    I have a C1200 filter and I experence a problem where the top handle and rod are corroded together and the previous owner addressed this by having the bottom of the rod unscrew from the base of the filter. Unfortunately this means that it takes a ton of time to reattach the rod of the filter because you have to thread the rod just right.
    I happen to pick up a broken C1200 with the same rod/handle assembly I want to swap, but I can't figure out how to unscrew the metal rod from the bottom. Any suggestions?
    Casey's Avatar
    SW PA
    10,428
    Re: Removing/Replacing rod from Hayward C1200 filter.
    Not sure but someone has to know....
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    The rod is screwed into the base with some material to help make it hard to come out.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
