I will need to bring the water about 1/2 way on the skimmers probably in a few days, given the weather will be hot in NJ this week.
I tested the well water:
The PH was a wierd color (seemed very low). The TA and CH colors did not match at all. Then after 2 drops in each, the color change reflected the TF-100 test kit. It appears that TA is around 20 and CH is around 50.
HOUSE WATER:
The PH range is between 7.5-7.8, while TA is 70 and CH is 100.
Question: I need to fill up and am assuming that I should use city water and not well water. I have used well water in the fast (few times). The initial fill was from the city (NJ American Water Company).
HOUSE WATER:
