Thread: Is this skimmer part necessary?
    Jul 2015
    Cape May Court House, NJ
    121
    My PB told me to remove this part (the white disk in the photo) from my skimmer and store it in my shed because I don't need it. What is it and what is its function? It sits in the skimmer above the basket, so I would have to remove it every time I empty the basket. There's a spring-loaded screw valve on top that says "fast" and "slow". Any advice?
    22K 16'x40' inground fiberglass pool, Hayward Pro Series High Rate Sand filter, Hayward dual speed 2 hp Super II Pump, Hayward AquaRite SWG, Raypak 400K btu propane heater, Dolphin Supreme M400 cleaning robot, CoverPool auto cover. Also stand-alone Sundance Hawthorne 430 gallon hot tub.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Is this skimmer part necessary?
    I've got no clue? Never saw anything like that before. Gonna give this a bounce and see if some of the pool building guys know?
    38,463
    You sure it is not supposed to be below the basket and allow you to force suction from the floor if your drain is plumbed to the skimmer? Maybe a different design for a float diverter.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    It looks like a skimmer equalizer valve. It is supposed to sit below the skimmer basket and block flow from the skimmer if the water gets too low or the skimmer basket is packed full of debris. The only way this would not be useful is if you do not have a main drain plumbed with a line to the skimmer.
    Love TFP? Become a
    TFP Supporter!
    Jul 2015
    121
    The skimmer manufacturer is Waterco. I checked their website and from their not-easy-to–read drawings it seems to be a "vacuum plate" to be used only when vacuuming and removed otherwise. The skimmer is so deep that if that's not in place I have to reach in with my arm well past my elbow to hook up a vacuum hose. I'll call the company today and see if I can get more info.
    Looks like skimtrol vacuum plate... Goes on top of basket when vacuuming
