Thread: Hidden Eden intro
    Hidden Eden's Avatar
    Jul 2015
    Escondido, CA
    2
    Hidden Eden intro
    Hello All,
    Just found this place and it looks promising. I just bought my 1st house and this is my 1st pool, so big time noob. I'm ok with being a noob, because we all start here.
    I've done an ok job of pool care so far, but I'm ready for the next level. So far I've rescued the pool once from going green, but little by little my pool equipment is failing cause it's pretty old. I'll update my signature once I figure the size of my pool. here are the generals that I know: @ 8' deep then shallows to about 3' 1/2", below ground, built in Jacuzzi, heater is dead, polaris 280 cleaner, Hayward DE filter. Guess it's time to measure the pool and get real numbers. I plan on reading through Pool School, and other tips are most welcome.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Hidden Eden intro
    Hi,
    welcome to TFP!
    Divin Dave,
    Jun 2014
    15,059
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Hi! You are going to LOVE it here! We will help you get your pool set up so that it will never be green again!
    Can you list your state by your name please?
    I love your old truck! NICE!
    Kim
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
    Jul 2015
    Escondido, CA
    2
    Thanks for the welcomes. I'm in SoCal
    18,000 gal Plaster IGP 3.5 - 9' depth / Manually Chlorinated, purex triton fns plus Filter, Polaris 280, Taylor K1004 test kit
