Thread: Hayward H400 Keypad broken
    May 2014
    United States,Las Vegas,NV
    8
    My heater Hayward H400 is stuck in spa mode, buttons do not respond any more, so I'm assuming that keypad bezel is possibly broken.
    I looked online and this keypad bezels are quite expensive, between 200-300 dollars.
    1. Are they difficult to replace ,
    2. And If i decide not to use heater at all, what will happen if I completely disable power to the heater, and just let the water pass through, since in past two years I haven't used heater at all.
    3. What is the easiest way to completely shut off heater, maybe disconnect it at the fuse box ?
    I'm looking for anyone help if someone knows something about this few problems.
    8.5K gal,spill-over spa IG Plaster, Hayward C2030 225sqft, pump hayward super pump II 2.5 HP 2speed SP3020, manual fill, built 1985, pool size 13' x 28', depth 3'x5', 1 x skimmer, 2 x main drain
    ps0303's Avatar
    Jul 2011
    FL
    3,699
    Re: Hayward H400 Keypad broken
    Not hard to replace and can be done by a homeowner.
    No harm in shutting off the heater and gas and just letting the water flow thru it. Yes if it has it's own breaker you can shut that off.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
