Results 1 to 9 of 9
Thread: Muriatic Acid Prices
    Wildcat's Avatar
    Jun 2013
    309
    While we post a lot of bleach prices I use a fair amount of muriatic acid also. What are you paying for 31.45% MA?
    I am paying $5.50 per gallon, HASA, clear,no yellow at Patio Pools in Tucson, AZ area
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Muriatic Acid Prices
    I believe I'm paying $4.99 at both places I've bought this season. It's been a while though. Menards and Fleet Farm in Waite Park, MN. The pool store charges $7.99. Criminals.
    Isolated Spa - 345 Gallons
    Wildcat's Avatar
    Jun 2013
    309
    How do you compare dry acid by the pound vs. liquid muriatic acid by the gallon?
    X pounds= Y gallons
    cvgnus's Avatar
    May 2015
    Massapequa, NY
    46
    I paid $3.65 for Crown 1 gallon 31.45% at Lowes. I picked up two. Sometimes hard to find as I took 3 trips to 2 different stores to get it. They also advertise Crown NEXT %15.725 for $2.04. If you don't mind working with muriatic acid, try to stay away from the dry acid as I believe it adds sulfates.
    5900 gal Oval 17' x 12' x 54" Sharkline Navigator 54 AGP; 1.5 HP Hayward Power-Flo LX Pump; Hayward EC65A DE Filter; AquaComfort XL ACT-750 Heat Pump;
    Hasa 8 gal Liquidator;
    TF-100 Test Kit w/Speedstir
    Jun 2015
    Phoenix, AZ
    73
    I use the ad from NPS Pool & Spa Supply and price match at Leslie's. I get a 2-gallon box for $6.39 and that price is currently good until 7/30.
    Jul 2013
    Chandler, AZ
    43
    NPS Pool & Spa Supply was bought by Leslie's. They are charging $14 now for 2 gallon box. Any idea where I can get for cheaper in the phoenix area?
    12x40 In ground, 16K Gallons, Pentair VS pump, 420 catridge filter, 140HC Heatpump, Stonescapes pebtec surface, Chandler, Arizona
    Apr 2016
    Phoenix, AZ
    22
    Quote Originally Posted by mmdhar View Post
    B & B Pools on Baseline and McClintock in Tempe - 2 gallon box of Muriatic Acid 31.5% for $8.69
    Phoenix, AZ | 30,000 Gallon Pebble-tec pool + attached spa | Hayward cartridge filter | Pentair Intelliflo Variable Speed Pump | In-ground pop-outs | Taylor K-2006 Test Kit
    Jul 2013
    Chandler, AZ
    43
    Quote Originally Posted by SunDevil1 View Post
    Thanks, I'll try that store.
    Feb 2015
    Chandler AZ
    926
    A&M Corsons on McQueen & Warner. Also on Val Vista & Southern.
    31.45% MA for $17.99/4 gallons - reusable jugs (initial $6 deposit on 4 jugs & carrier).
    Good fresh 12.5% chlorine too. $14.99/4 gallons. Look on their counter for the buy 3 get 1 free flyer to lower that price.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
